ShinerBock
May 02, 2015Explorer
RobertRyan wrote:ShinerBock wrote:RobertRyan wrote:
Their Pickup can tow 3.9 Tonnes(8,680lb) to put that into perspective, a Silverado HD Diesel is rated at 9,900lb here. It does not believe the numbers put out by Ford and GM
If Ozlanders honestly believe that a midsize Mitsubishi can tow a load just as good with just as similar towing performance as a 3/4 ton HD diesel then they are smoking some pretty good stuff.
Nothing to do with Australians,that is a Global standard. You pretty well summed them up. Your Midsizers are "lifestyle vehicles" These are built for in many cases extreme work
Actually NO!... I have done some more research and found out the reason why the US 2500 trucks are limited to 9,900 lbs and it has nothing to do with what you are wanting everyone else to believe. You should really come clean right now or I will. I will give you 24 hours.
44,070 PostsLatest Activity: Aug 08, 2026
