RobertRyan
May 02, 2015Explorer
ShinerBock wrote:RobertRyan wrote:ShinerBock wrote:RobertRyan wrote:
Their Pickup can tow 3.9 Tonnes(8,680lb) to put that into perspective, a Silverado HD Diesel is rated at 9,900lb here. It does not believe the numbers put out by Ford and GM
If Ozlanders honestly believe that a midsize Mitsubishi can tow a load just as good with just as similar towing performance as a 3/4 ton HD diesel then they are smoking some pretty good stuff.
Nothing to do with Australians,that is a Global standard. You pretty well summed them up. Your Midsizers are "lifestyle vehicles" These are built for in many cases extreme work
Actually NO!... I have done some more research and found out the reason why the US 2500 trucks are limited to 9,900 lbs and it has nothing to do with what you are wanting everyone else to believe. You should really come clean right now or I will. I will give you 24 hours.
Would love to KNOW your reason, seeing every other vehicle follows the same rules:R
I have a feeling you post on other sites using different names Love being contradicted by a flat earth believer.
44,070 PostsLatest Activity: Aug 08, 2026
