ShinerBock
May 04, 2015Explorer
RobertRyan wrote:
Shiner Box, all from the same press release as before Not comparing anything, they are just quoting the press release
So did you when you posted.....
RobertRyan wrote:
Instead of seeing this as a rehashed truck from another market, though, it's more accurate to look at it as a scaled-down Silverado, as few of the chassis components are shared with the global truck. The frame is about 40 percent lighter than the global Colorado's frame; the new unit is fully boxed and uses liberal amounts of high-strength steel. Comparing crew cab to crew cab, the Colorado is 900 pounds lighter, 5 inches narrower, 3 inches lower, and 16 inches shorter than the Silverado. The Colorado will use a coilover front and leaf-spring rear, and Duralife disc brakes with ABS. It will have EPS and an impressive 41-foot turning radius.
Hey look, it says Global Colorado in the press release you posted too. Who da thunk it?
44,070 PostsLatest Activity: Aug 07, 2026
