BenK
Nov 14, 2014Explorer
Mine is the same, except 1996, 4.1's and over 165K miles of extremely
hard driving/towing/offroading
GM's G80 is
It does NOT need, nor does GM recommend any LS modifier
LS Modifier reduces the clutch pack from sticking...exactly what the G80 wants to
do when the centrifugal switch turns on the locer
Recommend you flush and refill with synthetic diff fluid WITHOUT any friction
modifier for LS diff's
I've used Mobil synthetic since new.
A trick, as this era does NOT have a drain plug.
Remove the diff cover and flush.
Scrap off any old gasket on the diff housing and cover.
Degrease it well
Then glue (Permatex) the new gasket on the diff cover side.
Lightly coat the diff housing flange with diff fluid. Ditto the gasket
side that will mate
Then reassemble and tighten the diff bolts 'lightly'
DO NOT FILL
Leave it this way for a couple hours...best over night
Then tighten the bolts to sped and refill
Next flush: just loosen all of the diff cover bolts, but leave them
on
Place a catch pan underneath the diff pumpkin
Then whack the diff cover. Normally dead center, but on GMT400's the
gas tank is very close and in the way
The diff cover will just pop off and a gush of fluid
Then take the bolts off.
Wipe the diff cover and gasket
Let it drain and then repeat the wipe of fresh fluid on the mating
surfaces.
No new gasket, as the old one will be in one piece.
Tighten and then refill...done
Flush mine every 20K miles or two years...which ever comes first
GM's G80 is
NOT
a limited slip, but a LOCKER with clutchesIt does NOT need, nor does GM recommend any LS modifier
Degrease it well
side that will mate
DO NOT FILL
on
surfaces.
