oughtsix
Nov 15, 2014Explorer
It has been my experience that differentials are not very prone to wearing out... although I did have a friend that was able to grenade the front Dana 30 in his jeep 3 times before he finally upgraded to a Dana 44 (A Dana 30 doesn't care for 36" Swamper tires).
At 150K I would guess the clutches are worn out but once the clutch pack is gone it should function at a regular differential for just about ever.
A 20 year old differential should not be very expensive at the local junk yard if it does blow up on you but being stranded sucks! When I upgraded the front of my 67 F100 with an 82 Ford 1 ton front end with power steering I think I paid all of $200 for the rear Dana 60 so my front and rear bolt patterns would match.
I would look at the wheel bearings before I fretted over the diff too much. Changing the bearings in an axle generally isn't too difficult. The full floaters I have worked on had C clips holding the axles in the carrier in the diff so I had to remove the diff cover to get the axles out. Some axles lubricate the wheel bearings with the diff oil and don't require packing with grease.
