X3...
Most all full sized pickups and SUV's ranging from half ton to higher class most all use the exact same body basis with a few add on accent stuff to make it look bigger
Therefore the general confusion on that. Plus half ton's these days are more fake 3/4 ton than the older 6K GVWR half tons
Taller, yes and a few local kids & one guy that must be in his 50's (still 20 years younger...as am going to be 70 this year) think and always tell me that their 'half ton' cars (not trucks...as they really are) are more capable than my lower 8.6K GVWR & 6K RGAWR Suburban...
They can't go into the local parking structures, where as I can...they can't keep up on long, sweeping highway overhead curves either. Because their CG is way higher & my track is +10.5 inches wider than stock.
But...this is the fat part of the bell curve that OEMs base their sales on...the fashion statement crowd...and rightly so, as it is a business to make money
IdaD wrote:
Ralph Cramden wrote:
martinto wrote:
And the creature comforts without the big size that comes with 3/4 and 1 ton.
I always scratch my head at the above? Big size where. 1500 or 2500 or 3500 in the same cab/bed, is the exact same wheelbase, width, and overall length. The 2500/3500 usually has a slightly larger turning radius due to the suspension. Overall height is a few inches higher as is ground clearance, but it's basically the same size as the body panels are exactly the same....at least with GM.
Bigger springs, brakes, axles, driveshafts, u joints, and a whole host of other things too, but thats not exactly a bad thing?
I have never been able to grasp the bigger thing on boards. Hell I've seldom been able to digest a truck thread lol.
Ditto. My Ram actually turns quite a bit tighter than a same year/configuration F150. Taller is the only dimension that could come into play in a low parking garage situation. Beyond that HD trucks are heavier but they aren't any "bigger" in dimensions. I personally think HD trucks are a better value proposition than half tons because they don't cost materially more so the additional capability is basically free. But they also don't incur the downsides of living with a dually, so to me they're the sweet spot. YMMV.
