time2roll wrote:
Unless the Prodigy plugs into the OBD port it cannot perform as well as the factory unit.
Disagree and IMHO, MC pressure sensed does NOT turn on the trailer brakes as soon as a TV brake pedal switch sensed like the P2/P3
Plus, an MC pressure sensed does NOT continue to increase the trailer brake voltage when the TV brake pedal is NOT pressed any farther after setting the switch
Think most who don't like a P2/P3 did not setup their TV brake pedal switch well
I can touch and hold the TV brake pedal a small fraction of an inch to turn on the pedal switch and not press any farther. This is akin to leaning over and manually sliding the lever/button on most any after market and even the OEM IBC
That will have the P3's accelerometer sense deceleration and send ever more voltage to the trailer brakes all the while the TV brakes are not braking.
This way I can stop the whole TV/Trailer without getting the TV's brakes turned on and is why my P3 leads the TV brakes....and can decide to brake the TV if I should want to
With any highly integrated trailer brake system...they are integrated into every computer on the TV (or most all) and is a potential wonderful thing...if...they all work well....but....if anyone of the other computers/sensors has an issue...the whole braking system might/will barf
The cost has a very large potential to diag and fix. An add on like my P3 is warrantied for life and a brand new one costs under $150 on sale...should have kept my P2 as a spare in case something happens on the road with my P3 (not likely, but poop happens)
Personal choice and mine is to keep it simple (KISS philosophy) and NOT tie into the TV's network of computers
