BurbMan
Jul 07, 2020Explorer III
My 2001 Suburban had both...AWD was called 4WD "auto" with a viscous clutch that engaged the fronts based on wheel slip as needed, you could also select real 4WD and 4 LO range. So including the neutral position, you had 5 choices on the t-case selector.
44,066 PostsLatest Activity: Mar 14, 2015
