mkirsch
Jul 08, 2020Nomad II
AWD and traction control probably would have worked well in that situation.
Traditional 4x4, even with a limited slip or locking rear diff, is at best a THREE wheel drive system, and that one front wheel that's spinning doesn't bring anything to the party except some slung mud. If you've got open diffs front and rear then you're down to a TWO wheel drive system, and the wheels that get power are always the ones with the LEAST traction.
AWD doesn't let you get to that point. If you're stuck, you're truly stuck because all four wheels have no traction. You're not stuck because the two wheels that might be able to get a little bite are just sitting there while the other two spin.
AWD will cover 99.99999% of cases, except maybe rock crawling or mud bogging. If you're doing those with a brand new production vehicle, I'd call your sanity into question.
44,066 PostsLatest Activity: Mar 14, 2015
