jaycocamprs wrote:
v10superduty wrote:
However I want to point out something I noticed in GM press release about very different construction technique.
Ford is going to rivet and glue where panels meet, mainly ones of dissimilar metals..
GM is going to weld..
Here comes the stirring..:W
While in the marine business I was heavily involved with product from Brunswick Corp.. Merc outboards and their lines of aluminium fishing boats. Princecraft (premium Canadian made boat)Lund, Crestliner, and Lowe.
Not going to discuss Lowe cause was an unknown in our parts but the other 3 very common.
Princecraft used rivet and glue construction.
Lund used rivet construction.
Crestliner used welded construction.
In commercial use where a year equates to about 10 to 15 years of a recreational user who goes out every second weekend, the weakness of each showed up.
Over time the Lund and Princecraft would need a few rivits tightened which is a do it yourself repair if there is no floor structure in the way.
Over time the Crestliner would crack lengthways along the edge of the welds. Major repair here and usually was just a bandaid till it recracked along the edge of the new repaired area.
Does this relate to trucks that no one has bought and used yet? :@
We will see wont we..
I know which construction technique I would want.
Peterbuilt, Kenworth and Freightliner have used riveted aluminum construction on their truck cabs for many years.
Kenworth uses huckbolts, instead of rivets.
As far as the weld vs rivet comment, aircraft use rivets and develop cracks all the time. It is the nature of aluminum, not the fastening method. Rivets and glue are preferred in a production environment because it is cheaper than welding.
