travelnutz
Jun 19, 2013Explorer II
The supplier to GM of the tailgate cables did not crimp the the cable ends correctly and they were also incorrectly tested and certified during their production. The improper crimp could have caused cable pullout with corrosion weakening over time as moisture etc could collect in the loose crimp voids and compromise the assembly.
Only a few had failed but GM recalled the trucks that had them installed as the possible failure would only get worse with aging. It cost the supplier dearly and if I remember correctly, either it finally bankrupted them or they were dropped as a supplier. Was around 10 years ago.
Causing a recall due to production errors is a cardinal sin! Certifying discrepantly manufactured components as meeting specifications is a double sin!
