Kayteg1
Sep 12, 2015Explorer II
Reddog1 wrote:
If loading your TC takes weight off of the front axle, your CG is incorrect. It will have a negative impact on your steering, how negative depends on how much weight is removed from the front axle.
Wayne
My Fleetwood seems to be a bit unique with holding tanks under rear bumper and generator and propane tanks in the rear as well.
Also I put the trailer 16" behind the cabin to have cargo space.
Obviously I am not driving with full holding tanks very often and diesel engine is giving enough load on front axle to not create problems.
Still something you should remember when loading TC.
44,066 PostsLatest Activity: Oct 04, 2013
