Ruger3739's avatar
Ruger3739
GMC Sierra 1500 Towing Advice
Hello,
First time poster long time reader.
I have a 2012 GMC Sierra 5.3 6speed with 3.42 gears. I have the tow package with trans cooler.
I read these forums for a long time and tried to buy a trailer that would not overload my truck. I ended up buying 99 Komfort 25 foot bunkhouse.
After all this reading I became paranoid lol. I loaded up my trailer with everything except food that would go in the fridge, beer and drinking water. I loaded up the family and headed to the scales. ( I also had some junk in the back of my truck that added another 100 pounds.
My sticker on the door info:
GVWR:7000LBS
GAWR FRT:3950
GAWR RR:3950
Payload:1560
I also did a stupid thing before I knew I was going to be getting a trailer and but tires 2 sizes larger on. Good news is they are E rated
And I have a p3 break controller and ez lift WD hitch and Friction Sway.
Results from Scale:
Front Axle: 3260
Rear Axle: 3500
Total: 6760
Trailer Axle Weight: 5820
My question is: Is it unsafe for me to be this close to my GVWR? I'm not white knuckled towing it on flats but would like to go up to some lakes in the mountains and there are some tough grades 7% and one 9% (shaver and Huntington lake if anybody knows the area).
I know a 3/4 ton would be much better and I am considering it but I love my truck and have added a lot of nice features that I would not be able to afford to do if I went with a 3/4 ton due to their price.
Weight police welcome. Please tell me I'm crazy and to get a 3/4 ton or I'm over thinking this and am good to go.
Thanks for all the great info I have already read!
  • Read my sig. I am close to mine and tows okay, I would not take it west and go over Pikes Peak tho.
    Pikes Peak is a dead end road, and they want let you pull your trailer to the top :)
  • We are quite familiar with that stretch of road, hiwy 168 has a b-t-h of a climb on the 4-lane section. On several occasions we towed a 5K 5vr with 90 5.7 Chev 1500, 4-sp, 3.73 rear. Also with 02 5.3 Chev 1500, 4-sp, 3.73.
    Weight wise, you should be okay. Keep rmp up and gear down, both directions.
    We even towed large Jayco tent trailer with 75 Ford Courier. Low gear, speed around 25 mph. No problem.
  • Kudos for taking the time and getting the weights and for being concerned for your family's, and everyone else's, safety. Your numbers look awesome so enjoy and don't worry.
  • Your under the numbers so that's a great set up. Tow and enjoy it.
  • I go by what the manufacturer says. They designed it and tested it.
    Others prefer a 20 or 30 percent safety factor.
    You pull what you are comfortable with, I have no issues with a my EcoBoost F-150 pulling a 5000 lb. 26 ft. Dutchmen. I would not want any thing much bigger.
    GVWR:7000LBS
    GAWR FRT:3950
    GAWR RR:3950
    Results from Scale:
    Front Axle: 3260
    Rear Axle: 3500
    Total: 6760
    My question is: Is it unsafe for me to be this close to my GVWR? Please tell me I'm crazy and to get a 3/4 ton or I'm over thinking this and am good to go.
    Nope, 3/4 ton not needed. Just get a Ford! :B Just kidding. Your numbers say you are fine. Just be careful on what you are loading. You are to be commended for actually thinking about capacity and checking on it.
  • The GVWR on the sticker on the door jamb is for the truck, i.e. curb weight + payload. The GVWR of the trailer you can pull with that powertrain should be 9500# - 9600#. You can breathe easy now. ;)
    However the limitation with that truck will be payload.
