Photomike wrote:
You do not need to flush out all the water with pink. Pump out the fresh water tank till pump pushing air, add a container of pink, pump through, add some to drains and you are done. Air works as well but I like the pink in the pump to reduce the expansion.
As it is around here it is not that cold, only -28 tonight. Must be time for a barbeque.
I do the same thing. Air first then pump some pink stuff through the pump, some down the drains and a little for the toilet.
You had better get that bottle of Bulls Eye BBQ sauce off the BBQ or it is for sure going to freeze and also if you would please keep your cold weather up there and quit sending it down to us. :M :B
