hohenwald48 wrote:
I think most experts (ie manufacturers) will recommend that you should always inflate tires to the maximum sidewall pressure when they are used in trailer applications. In other applications it is normal to adjust pressure down if the applied load allows for a reduction in pressure from the maximum. However, that is to soften the ride in a passenger carrying vehicle. Since TT's don't normally carry passengers a soft or harsh ride is irrelevant.
Maximum sidewall indicated pressure gives the tires their maximum load carrying ability. If your trailer is so heavy that it exceeds that then you need a different set of tires anyway. If your trailer is lighter than the maximum ability of your tires there is no reason to reduce the tire pressure to match that lighter loading.
It sometimes seems that passenger tire information finds it's way into travel trailer tire discussions. They are two entirely different applications and what applies to one does not necessarily apply to the other.
From everything I have ever read, trailer tires should be inflated to their maximum sidewall pressure rating. Anything less creates unnecessary heat and has the potential to cause tire failure. Having said that, it's your trailer and your tires so you should certainly do whatever you want.
However, I wouldn't be too quick to take the trailer manufacturers word for it. It's very possible they printed the manual for a different tire size than you have currently installed. They rarely keep their manuals up to date and previous owners could have easily changed the tires from the ones installed by the manufacturer.
THANKS for the detailed explanation.. Very helpful! I have learned a lot about my new TT from these very helpful forums! Much appreciated!
