acut2660's avatar
acut2660
Good parking surface?
So my wife and I will be bringing home our new travel trailer in a month and we need to decide what is the best surface to park it on. I am trying to decide if I should extend and widen my driveway with asphalt or if I should just excavate the area that I would pave and fill it in with gravel. Any and all suggestions will be great. The TT GVWR is 7,500lbs, and my area is sand based not clay.
  • I'd do gravel with some concrete pads for the tires.
  • 2112's avatar
    2112
    Explorer II
    I have been parking mine next to the driveway, unpaved, for years and have not had a rust issue. I have 2'X 4' strips of 3/4" plywood under the tires to keep the tires off the ground. This also makes it easier to weed-eat around. I replace to wood every three years or so.
    Now granted, there hasn't been GRASS on this spot since we bought out first camper 14 years ago.
  • Lowsuv wrote:
    it has been posted previously that parking on GRASS has accelerated the rusting of the trailer frame .
    I can say from practical experience that the trailer life is probably double if parked under a carport rather than exposed to the sun / snow .
    if your budget is tight you may do it in steps .
    gravel foundation now with vertical 6 x6 framed carport .
    in a couple of years , pave it .
    in a couple of years install the walls .
    X2
  • it has been posted previously that parking on GRASS has accelerated the rusting of the trailer frame .
  • Is there any benefit to the paved driveway? It is cheaper by a long shot to do the gravel. Especially since I have the equipment to excavate and fill in the gravel.
