- Camper76Explorer
handye9 wrote:
As stated above, your dry weights are useless. That 780 tongue weight will be closer to 880 before it leaves the dealer lot. Everything you put in your master bedroom and front storage area will add directly to the tongue weight.
I used to have a similar floor plan (different MFGR), with similar dry weights. Ready to go camping, my tongue weight was pushing 1100 lbs.
It's one reason I want to go bigger them need - handye9Explorer IIAs stated above, your dry weights are useless. That 780 tongue weight will be closer to 880 before it leaves the dealer lot. Everything you put in your master bedroom and front storage area will add directly to the tongue weight.
I used to have a similar floor plan (different MFGR), with similar dry weights. Ready to go camping, my tongue weight was pushing 1100 lbs. - Camper76Explorer
LarryJM wrote:
Camper76 wrote:
LarryJM wrote:
Camper76 wrote:
I'll be towing a Jayflight slx 294 qbsw. Dry hitch weight is 780, trailer dry is 6480, Gvw is 8250. I want something a little bigger just so I won't need to buy another one if we ever get bigger trailer.
Since you obviously have something now that you're using
1. What is it
2. Get to a set of scales and get some REAL NUMBERS and not those useless "DRY" ones you are now using.
3. Depending the min would be around 1200 with a probable end one in the 1500 range, but those are TOTAL GUESSES at this point. But what you now have is a fairly heavy trailer already so not sure how much heavier especially hitch wise you could get.
Larry
I have Reese with tounge weight of 1000lbs and 10000 gross. It has sway arm so I can't back up with it. Also I'm towing with ram 1500 hemi not sure if that helps
You also need to make sure you educate yourself since if that "sway arm" is the friction bar type you can in fact back up with it. You just have to be careful about making "EXTREME" turns and not accelerating slowly when backing and I always loosened it if I was expecting to make many maneuvers backing into a site.
I have the 1200/12K Equal-i-zer for my 1K TW 32' 7500lb GVW trailer and am totally satisified with it, but that's behind a 9500lb 1T full sized Ford Van.
Larry
Does it make a lot of noise. Cause the one I have is noise as hell - LarryJMExplorer II
Camper76 wrote:
1. What is it
Larry
You also need to make sure you educate yourself since if that "sway arm" is the friction bar type you can in fact back up with it. You just have to be careful about making "EXTREME" turns and accelerating slowly when backing and I always loosened it if I was expecting to make many maneuvers backing into a site.
Larry - Camper76Explorer
1. What is it
Larry
I have Reese with tounge weight of 1000lbs and 10000 gross. It has sway arm so I can't back up with it. Also I'm towing with ram 1500 hemi not sure if that helps - LarryJMExplorer II
1. What is it
Larry
44,056 PostsLatest Activity: Nov 19, 2013
