I just purchased four Marathons same size you are looking at from Sam's Club the end of April. They cost $135.00 each mounted balanced and including all taxes out the door. I did not know where they were made until they came in to the store as they were special order sure enough they were stamped made in China. I have 1000 miles on them to date they seem fine. The only problem with buying at Sam's is I had to park in their lot jack the trailer up one side at a time remove the wheels and take them to the shop door as their workers are not allowed to work outside the shop and their doors are not high enough to pull your trailer in. Regardless everything went well and I was out in less than an hour.
