Nvr2loud wrote:
gmw photos wrote:
Nvr2loud wrote:
Lower pressure for same weight rating results in a less stiff sidewall and can increase sway. ST tires are designed for trailers, where LT tires are designed for pickup trucks / vans
Using that logic, how do you reconcile that so many trailer manufacturers fit and/or approve LT tires for their trailers ?
Never seen that before, not saying it isn't true, but every trailer I've ever purchased (travel trailers, boats, utility enclosed, and car haulers) have ALL had ST tires on them. I would assume that lower priced trailers would have lower priced tires. ST tires do cost less, so therefore it would make sense to me that a lower priced unit would have ST tires. LT tires can certainly be used for trailers, they are rated for trailers, but with some sacrifice of sidewall stiffness.
An LT tire is a better tire, it offers better traction for the tow vehicle, nicer ride, designed for cornering and braking. An ST tire is designed to follow along on a trailer. Traction is not as important, so the sacrifices in traction and ride comfort translate to stiffer and better for a trailer.
I already said, given the choice, I would run LT tires on my trailer, they are of superior construction and I trust them more. But the question posed to me is WHY an ST tire is better for a trailer, and I still feel an ST is designed better for a trailer then an LT.
I have in front of me, the owner manuals for both my Titan horse trailer and my LoadMax equipment trailer.  Both state LT tire are approved.  I am getting ready to buy a 4Star horse trailer, I looked at their owner manual online, they too approve LT.   I've looked at Kieffer Built, and Logan coach manuals.  They too approve LT.
In the RV world, Airstream and the new Oliver come to mind as companies  ( as well as others ) fitting LT as original equipment.
The handwriting is on the wall, and it's scribbled in great big letters....."when you want to step up from cheap"......the step is from ST to LT.
Cheap.   That's all we need to know about the subject.
 I have better, and safer things to do with my time than sit at the side of the road with 18 wheelers zooming by a couple feet away while I change a "cheap" tire.
Hey those of you who want to run ST's...knock yourself out.  Good luck with that.  But let's not try to confuse the issue to newbies by throwing nonsense around about some superiority of ST tires.  Their "strength" is in their low price point.
