mike445's avatar
mike445
Got a "new" popup.
When I bought my Wildwood 372 REDS destination trailer I sold my popup. Its been 2 years and I am REALLY missing my popup!! I thought I'd look around for another trailer. I found a gem!!
I just recently bought a 1995 Rockwood 1940 from a family who has taken VERY good care of it. The trailer is perfect, it looks new inside and out, there are no signs of wear at all. It has new tires, brakes, bearings, springs, and winch cable. It is stored indoors when not in use. There is no mold, the canvas looks like new inside and out!! I got very lucky! I pick it up in April (keeping it stored for the winter).
That being said, does anybody have ANY info on a 95 Rockwood 1940? I can't find anything at all. I'll be towing this with a Chrysler 300 and a Dodge Charger. Can't even tell its behind the 300. The trailer has an indoor/outdoor stove, a 3 way fridge, furnace, awening, screen room, and sink. I'm going to add a 12 volt entertainment center (car stereo, 12V LED TV/DVD combo). Will also be adding a CB radio and police scanner (for when at the races) Will likely swap out the 12V battery for 2 6 volt GC batteries and throw a decent size solar panel and controller on for good measure.
When Spring comes I have to figure out how to install the antennas (all magnet mount) on the roof. Also want to get a Winegard TV antenna and Create a Breeze fan installed, but that I won't do myself.
If anyone has any ideas how to install a CB, scanner, and radio antenna throw the ideas at me!! I have a few months to figure it out. I can't wait to take this little trailer on its first trip!!!
Mike
  • RoyB wrote:
    I mounted two ham type antennas on the rear end of the roof side using this bracket from a mirror mount antenna install. This should support CB type antennas as well. I too don't want to drill holes thru the roof of my trailers but the side walls is open game for me haha.. Been running my unit for over five years now with no known water leaks thru the side holes that are all sealed with RTV. All of my cabling is hide inside and no wires visible except where the main radio are mounted behind a wall. All my radios use a remote control head and speakers from one location as shown below.
    This is mounted on the side panel of the roof and penetrates to the inside allowing me to follow the valance curtains around to where I can drop down to the main trailer 12-foot box using the sewed-in cable path of the tent trailer window flaps.
    This is on my fifth wheel roof line. Using the metal clamp shown gives you a spot to cover the the hole thru the side and fill with RTV to seal it off.
    My 2008 STartcraft RT series OFF-ROAD Trailer floorplan is shown here with several radio items and antennas installed
    The rear end of my trailer is a wrap around lounge type seating giving me access to my radio console shown in the one side. Radios and Computer ops support my emergency radio ops with RACES/SKYWARN/NAVY-MARS setups back off the power grid trails...
    One thing to think about on using the older scanners now. Most of the US has gone or is in the process of changing all of the radio scanners out for the new digital radio scanners which support many channels on a single frequency. These require a very expensive new digital radio to monitor them ($500 range). I still get use my older scanners still but seems like every month now another group is no longer readable. All you hear now is a loud BRRRRRR ending with a squelch tail haha...
    Enjoy your 1995 Rockwood Freedom Series Trailer..
    Roy Ken
    THNAK YOU SOOOO MUCH!!!!! That post gave me so many ideas!!! I will mount my antennas in that exact manner. That is perfect!! I know what you mean about the scanners! LOL! I will be using a Uniden HomePatrol-1 which is capable of receiving the digital transmissions. I also have a GRE PSR-800 and a Radio Shack PRO-96...I will pretty much only be using the HomePatrol in the trailer.
    I have the NMO mount, cable, and antenna for the scanner. I'll buy a side mount CB antenna that is wind resistant. I just have to find a radio antenna that can mount at a 90 degree angle. I wonder if a scanner antenna will receive Am and FM well enough? I'll have to investigate that!!
    On my previous trailer I had a CB installed but I had the antenna mounted to the bottom of the frame rendering it useless. This is a MUCH better idea!!!!
    I can't wait to start toying with the "new" Rockwood!! I'll be posting pics of it the weekend of November 1st before she gets put to bed for the winter.
    Mike!
  • RoyB's avatar
    RoyB
    Explorer III
    Roy Ken
  • That sounds like a great idea for the antennas! Thank you. I don't want to drill any holes on the outside at all. Thanks! I'm excited to get it out and on the road. I have all winter yo figure out some solutions for everything.
    Thanks Frank. That is pretty much identical to the 95 I bought!!
    Mike!
  • There is a 1940 LTD on Rockwoods PUP site
    http://www.forestriverinc.com/PopUpCampers/RockwoodTent/default.aspx?model=rktc&page=floorplandetails&floorplanid=113&RVType=TNT
    Frank
  • If the antennas are magnet, they will not stick to the aluminum on your pup. But, you could take a piece of of steel, with some good old Liquid nails, just glue the metal to the roof and let it dry. Then you've got somewhere for the magnetized antenna(s) to attach to. This way, there's no holes to drill. A little paint and *Presto* you got your CB antenna mount!
    Not sure about your other questions. Hope this give you a some new ideas!
    Good luck, enjoy the PUP!
