billyray50's avatar
billyray50
Got high beamed last night!!
We have been in our new Adventurer 910DB since October 14th after closing up our TT for the winter here in upstate NY. Heading back to Dallas Monday and have not driven the truck/TC setup at night. Last night while returning back to my sons house we were flashed with high beams 6 out of maybe 16 times. Have not weighed TC yet fully loaded but was surprised at how much the Truck squated when loaded on my 2015 Ram 3500 DRW with 5565 payload. This Adventurer with one slide and dry bath is heavier than I thought. Will not be driving at night on return trip. Did not like airbags on my previous 06 Ram 2500. Caused to much sway. I am thinking of replacing stock shocks with Bilsteins and upper stable loads first after We get home. Any Thoughts would be appreciated.
  • I think Stableloads might be the easiest way to go if you load the camper several times a year, I have those and air bags and don't get flashed but Dodge might be set up differently
  • I'm not sure why anyone would not expect squat when you load a heavy camper. Springs deflect under load, that is their function and what they were designed to do. Most pickups in the last decade or two will squat 5-6 inches between empty and full load. If you make the springs so stiff that this is down to 2", the ride when empty will be horrible, and full not much better. If you expect the headlights to be aimed the same empty and full, you need to change something in the springs when you load the camper, or aim the headlights each time.
    Passenger cars squat also, but since the load is more equally distributed between front and rear, they squat close to the same and the headlight aim is not affected (as much).
  • Mark where your lights hit the wall when unloaded at a certain distance, then load up and adjust them to point to the same location at that same distance. Count how many turns it takes to get from A to B, and write it down somewhere. Then you can adjust back and forth with no hassles if you want.
  • billyray50 wrote:
    Thanks Jumbo. Did you replace stock shocks?
    Sorry for the late answer, but yes, with Bilsteins.
    And you don't want those overload springs to be engaged when empty. A few inch space is provided for your comfort when empty.
    Otherwise, we just bolt that frame solid to the axle.
  • I just leave my fog lights on all night long, since fogs are not supposed to be on during high beams on, on coming traffic knows lights are low beam:W
