cmarkj's avatar
cmarkj
Gray/black dump system - am I nuts?
I will be as brief as I can be. I just bought a Denali 289RK. It has 2 gray tanks (one up front and one in the back). The one in the back is for the kitchen and has its own dump valve. The one up front is for the bathroom and is tied in with the black tank.
Normally when the black and gray tanks are tied together, the gray ties into the dump line down stream from the black tank valve so you can dump the gray if it is full and the black tank can stay isolated (correct so far??)
The under carriage of the Denali is all sealed so I can't see what is going on, but I know one thing for sure right now......in order to dump my front gray tank, the black tank is dumping right along with the gray tank. The gray tank is tied into the dump line up-stream of the black tank dump valve, not down stream to be able to keep the black tank isolated.
I really hope I haven't confused everyone, because I need some help. If this is designed this way, and not a build screw up, all their engineers should be fired.
Their paperwork says that the black tank level should be at least 3/4 full before dumping the tank. The way it's set up now, if the gray is full and the black is at 1/4, the black is getting dumped way too soon
Please help me......
  • Bucky Badger wrote:
    Are you sure the 2 grey tanks aren't tied together?
    Have you put a clear fitting on the one you are worried about to see what is going on. You could put different food coloring in each tank to see what is draining
    I opened the dump valve for the gray tank for the kitchen and closed everything else. I then filled the bathroom gray tank until the water was coming up out of the shower drain. Nothing came out of the back dump valve. So I would assume that the 2 gray tanks are not connected.
    Then to dump the filled gray tank in the back, I had to open the 3" dump valve after I opened the 2" on the gray tank line. The black tank goes straight to the 3" valve.......so, in order to dump the back gray tank, the black tank will empty at the same time. Designed this way or a manufacturing screw up?
  • Are you sure the 2 grey tanks aren't tied together?
