Grit_dog
Dec 22, 2021Trailblazer
mkirsch wrote:
Admit it, if they'd changed the oil you'd be complaining about them performing services you didn't ask for and charging you.
But when they did the lifter service on mine they had to drain the oil to look for bits in the bottom end. So I got a fresh oil and filter as part of the service. You sure they didn't do that for you?
Yeah, in some scenarios, yes, but since the dealers are the cheapest spot around for an oil change save for my own garage and the oil apparently “needed” to be changed not only per their recommendation UR also the oil life minder, not sure I’d have complained either way although should be part of the warranty service.
44,071 PostsLatest Activity: Aug 16, 2026
