DWeikert
Sep 08, 2014Explorer II
Great RV Service Shoutout
Just wanted to give a shout out for Abe Thompson RV Service Center, 510 N Broadway, Oak Grove, MO 64075. (816) 690-2163. About a quarter mile north of I-70 roughly 8 miles east of Kansas City.
On my recent trip to Colorado it dawned on me shortly after hitting the road that I forgot to test the water heater before leaving the house. This, of course, planted the seed for problems when I tried to use it the first time on the road. The first fire-up it just belched yellow flame and a lot of soot. So I hit a Home Depot and picked up some canned air to give it a good blow out. After that it wouldn't light at all, though the igniter was sparking away. I figured I had blown whatever was clogging the orifice further back in and was blocking gas completely now. I stopped at a Camping World near Columbia, MO, but they didn't have time to look at it. Fair enough. People had made appointments and expected work done while I was just a drive up. No hard feelings. So I got back on 70 and saw the sign for Abe's and took the exit. I described the problem and they told me to pull around to the middle bay door (which had a camper in it) and "Bear" would come out to take a look. I turn off the propane while on the road but when I turned it on at Abe's I had zero flow. At that point we thought the main regulator was the problem so "Bear" and "Frenchie" pulled the regulator and Bear said he was also going to test the hose. Some time ago the hose had a kink in it and apparently something inside separated blocking propane flow. Once they found the blocked hose, they put on a new one, tested my original regulator and everything worked. I was charged for the hose and an hour's labor for the hour the two guys had spent on the problem, and I was back on the road a happy camper. But not before they gave me a marker and sent me into the waiting room and asked my to add my thoughts to the innumerable other thanks for great service scrawled on the wall.
If you're passing through the area, or live there, and have problems, you would have to do a lot of searching to find friendlier service.
Thanks Bear, Frenchie and Abe.
