Rider7767
Apr 29, 2014Explorer
Caveman Charlie wrote:Caveman Charlie, Thanks for the advice. I am thinking about adding the extra battery prior to my trip. I will do a few more test in the drive way. Getting set up with a new travel trailer is expensive. I rationalized the purchase saying, "look at how much we will save on hotel cost, and we will not have to unpack". I guess the unpack part is right. I have found you can set around and find stuff to buy for a TT all day. Google is killing me!
I too converted all my lights over to LED. Then I added 2 deep cycle golf cart batteries to the front of my TT. I'm just a weekend camper and I've found I can go for 4 days without charging the batteries. I don't know if they would go longer then that because I need to go back to work after that.
Another thing you can do is cut back or eliminate on some of the parasitic draws. Like you said you need to keep the circuit board on your refrigerator and water heater going. But, if you have a newer unit with a digital radio they have a memory in them that is using electricity all the time. By unhooking the wire to the memory portion of your radio you can save a little there. If you have a built in propane/carbon monoxide/smoke detector you can replace those with external dry cell battery operated units and save some power there too. Please do not unhook them without replacing them.
