harley4275
May 10, 2017Explorer
CanuckCamper29 wrote:
Good afternoon.
I've got a leak in my gutter right above my entry door on my trailer. It is where the two pieces of gutter join.
I've tried to stop the leak by removing the original "sealant" and replacing it with clear silicone sealant. My first attempt didn't work so I removed the sealant and re-applied using a bit more. This didn't stop the leak either.
I applied the sealant to the bottom and sides of the gutter.
I'm wondering if anyone could recommend a different sealant or any advice on what to seal. I haven't sealed along the "top of the gutter" that butts up against the trailer wall and wondering if that is my issue. Before I applied even more sealant I thought I would check and see if other had experienced something similar and had fixed their issue.
Thanks in advance for your thoughts.
I used JBWeld . Works great .
44,071 PostsLatest Activity: Aug 16, 2026
