ScottandCathy
May 01, 2015Explorer
Had to replace the TIPM in my 2006 Dodge Ram
Went to use the A/C about a month ago and it was not getting cold at all. The compressor clutch was not engaging. Checked the obvious, ie., broken or loose wires/connectors. Had power at the switch inside the cab. Direct powered the clutch/compressor and system runs fine. Researching on the web led me to believe it could be a circuit fault in the TIPM. Had the system fully scanned and it showed the request for power to the clutch/compressor, no power out of the TIPM circuit.
Bought a Dorman Products Re-manufactured TIPM through Summit Racing. Came preflashed with most current version and my VIN# that I provided. Plug and play. I now have A/C and the new feature where the radio will stay on until you open the door or remove the key.
