jch2122's avatar
jch2122
Half of my outlets not working
Thanks in advance for any assistance. I have a 2010 Coachmen travel trailer, and since I got it there are 3 power outlets that don't work. The two near the floor in the main bedroom, and the one next to the bed near the floor in the other bedroom. All of the ones near the floor don't work, while the others on walls and cabinets do, which I'm not sure means anything, but it's worth mentioning. Is there any advice you can give as to where I should be begin with this? Thanks.
  • Krusty wrote:
    No, the fuses are just for the 12 volt system. You may have a faulty breaker or a loose connection at a breaker, or at one of the outlets. I would pull each outlet out, check for power and/or loose connections.
    Thank you. Ill do that
  • No, the fuses are just for the 12 volt system. You may have a faulty breaker or a loose connection at a breaker, or at one of the outlets. I would pull each outlet out, check for power and/or loose connections.
  • Neal B. wrote:
    Have you checked the ground fault breakers on one of the outlets? Usually in the kitchen or bathroom. Don't forget the breakers in the electrical center.
    Yeah, I tried both of those. Could it possible be fuses? They are on opposite sides of the camper though.
  • Have you checked the ground fault breakers on one of the outlets? Usually in the kitchen or bathroom. Don't forget the breakers in the electrical center.
