whazoo
Jan 26, 2017Explorer
The needle holes are easily filled with a seam sealer like for tents. I would highly recommend to do that. Also, the seam between the roof material and metal trim can be exacerbated by tightening the adjustable roof "brackets". I.E. with the top down and brackets adjusted tight to open the seam, then I would caulk and let dry. That way when traveling and closing the brackets, you're not recreating that same crack and over-stretching the caulk.
