johndeerefarmer
Jul 30, 2014Explorer III
TXiceman wrote:
I have a NMO mounted Larsen dual band antenna mounted on the right side lip of the hood.
If you are planning to go HF, plan to put up with a lot of RFI. I have tried all sorts of chokes and have everything bonded and I still get the injector noise. Ford is of zero help on the issue. A friend has his FT857D (same radio I use) on his 2012 3500 Duramax and no noise problems. He is using a larger Tarheel antenna than I have.
SO my advice to a HF radio operator, is to not buy a FOrd until they get their injectors properly shielded.
Ken
No HF, just 2M and 440. What kind of mount did you use? It doesn't look like the 90 degree Larsen would work? Do you have a pix?
Thanks
44,025 PostsLatest Activity: Feb 18, 2025
