covered wagon wrote:
I've got the older type. New in 2003 with my camper always sitting outside, the HappiJacks still operate without a problem. I keep them covered and shoot 3in One oil to the electric motor bearings where the corrosion occurs. I found this corrosion in the second year and made covers for them and learned how to oil them in 2005.
This may be the direction you should go even with the newer style as the motor housings, end plate and shaft bearings are unlike metals to some degree, so need lubrication each year. How to access and remove the covers from the newer style electric motors I would have to see them to tell.
Where exactly do you put the 3 in 1 oil? Do you remove the cover?
Zulu
