deminimis wrote:
Done/fixed. Popped cap off (after melting ice inside). Blew dry. Wd40. Blew that out and dribbled 20wt in there as best I could. Will do a more thoughtful job when not so far below freezing. For those that have toron into these, I assume, based on end housing shape, that it actually has sintered bronze bushings and not bearings. Is that correct? If so, 20wt (3 in 1) is ideal. Just went through this with a pellet stove blower. Thanks. Oh, a couple of wraps with a screwdriver handle in the bushing location freed the motor.
Watch the lube job on top of the screw jacks (under the gear head)... in the manual position you disengage the electric motor and the clutch can be lubed too much to hold and the jack will let the camper come down. Very dangerous.
