You're question doesn't make sense. I'll get to why in a second.
But first, why can't you pull the forklift stuff off of the other truck and use it? It's the same truck in every way, except for the suspension.
Now, you're question...what bracket are you talking about? The reason I ask is because on that truck, you could be talking about two different things. That is the generation of truck that needs brackets on the inside of the bumper that makes the bumper sturdier because they were flimsier than previous years from the factory. The brackets strengthen the bumper for the button type tie downs.
The second type of bracket you could be talking about is the bracket that slides over the buttons so you can attach your turn buckles and tie the camper down. If the truck has happijac front tie downs, I would assume that the buttons are also from happijac and you can get the brackets from them.
I believe this is what you need. And I believe they only have ever made one size. It's not vehicle specific.
