MORSNOW
Jul 25, 2016Navigator III
I have Happijac brackets for the same fuel door clearance issue you mentioned and use Torklift Fastgun tie-downs for ease of use. How tight do you run your tie-downs? I've been using my Happijac brackets for three years, with some pretty major off camber truck/camper twisting, and haven't seen any bending of the front brackets. The spring loaded tie-down shouldn't be over tightened and should be stretching/contracting as needed without bending the brackets.
