I drove the truck all the way home today and it shifted perfectly. I did notice this morning when it was acting up the the gear indicator in the dash wasn't showing what gear it was in unless I jiggled the shifter. On the way home it was normal. Could the switch on the side of the transmission make it go into limp mode ?
Turtle n Peeps wrote:
Does it go into overdrive or does the cruise control work?
The tranny is limping. Why is it limping is the question.
When mine did that it was the TPS. The TPS said one thing and the SS said another. I screwed around with the TPS for a while and finally gave up and bought a new one. I put it in and that was the end of the problem.
This should have set a code.
