Bobbo wrote:
I second the post not to use the bypass switch when running on a generator. Generators can and do fail, and if you have it bypassed, you have no protection from that. A GROUND/NEUTRAL bonding plug is easily made for about $3 and works wonderfully well. If you need that information, just ask and a dozen of us will tell you how.
When the display is in the "off" mode, the EMS functions (voltage check, ground check, error, etc) are bypassed/disabled. The surge protection function is
never disabled (per PMI user manual).
