Kayteg1 wrote:
Not really secure, but potential theft would have to spend some time figuring out the setup and getting 10 mm socket on extension.
Not only generator holding bolts are not visible, but close to the ground, so you can't stick your head under. The only key lock is on platform pin.
That should slow them down a lot !
Kayteg1 wrote:
As for cooling - my 2017 Ford displays digital thermometer when engine temperature goes over 215F.
Coming from 124F in Death Valley with 6300 lb camper, I was really pushing the gas pedal going 55 mph over the mountain pass. The temperature come up to 225F and dropped very fast once I come to flatter road.
That is starting to get a bit warm, but modern cooling systems use higher pressure than they used to
(about 21 psi instead of about 14 psi).  This gives you a higher margin before you coolant actually starts to boil
(about 270F) .
