cruz-in's avatar
cruz-in
Hayes Plug and Play Elect Sway control
Hi Team,
IMHO, this is an impressive devise. Plug and play electronic sway control.
Hayes Electronic Plug and Play Sway Control
Would not use it as my primary sway control, however might be cheap insurance.
Chatted with company about the brochure saying it was for use without wd. They say no worries using it with WD as long as you can find a place to mount it properly on the A-frame.
Just passing this on for info...never used the device so cannot comment on it....
  • Community Alumni's avatar
    Community Alumni
    I'm not sure if I agree with that it's the first of its kind. There was the Tuscon Sway Control from years back that make that same claim. It was a pretty effective unit. I don't think I would rely solely on it even if I didn't require a wdh. Electronics fail and experience anomalies all of the time. That would be terrible in the middle of a sway event.
  • The first line of their online brochure says:
    "Eliminates sway when weight distribution is not needed"
    Since most TTs need weight distribution for reasons other than sway, (to return the front axle weight) this device would not be appropriate in most cases. That's according to the manufacturer of the device.
  • Nah! I'd not use it. It's just another electronic gadget that is prone to breakdown. A non electronic, mechanical device won't break down down with electronic's failure when you need it the most!
    Beside, I use WD with built in sway control already.
