exploringcaroli
May 15, 2017Explorer
CamperMan78 wrote:
I wanted to know if anyone on here has had any true experience with the Hayes Sway Master Electronic Sway Control and if it really works and if it will be beneficial to get one.
Installed a Hayes Sway-Master last year and it's working fine on my rig. The 23.5' Oliver travel trailer weighs in at 4950 pounds ready to camp with empty water tanks with 450 pounds tongue weight. TV is a 2016 5.7L Toyota Tundra without suspension modifications. Not using WDH.
After installation tested the Sway-Master at 55MPH and sway dampened in 1 1/2 oscillation. Towing in high gusting crosswinds on I40, TN plateau area at 60MPH, and sway dampened within 1 oscillation.
The Sway-Master uses a GPS to sense speed and operates above 45MPH. If GPS signal is lost, the Sway Master is active at all speeds.
Talk to Hayes to be sure sway master is compatible with your TV.
44,056 PostsLatest Activity: May 04, 2014
