I have been blowing air through the lines for years and never had a problem with freezing temps.  I use about 20PSI and go through opening and closing faucets and the toilet.  I then pour a little antifreeze in the traps and pull the plug on the water heater till it stops draining.  I have never since 1987 put antifreeze in the lines.  I let air blow for ten minutes or so.  There's no reason not to do this.  It only takes a few minutes and works.  I made my adapter from the end of an old garden hose, a hose clamp and the female connector for the air hose.  I use to drag hose out from my garage but now I just use a cheap Harbor Freight 100PSI pancake compressor and blow out the lines before I leave the campground.  I got the compressor cheap with a coupon and leave in in the RV all the time.
