Mikell's avatar
Mikell
Heki 2 Skylight Inner Frame Failure
Anybody had this happen yet to their Heki skylight? The inner frame point where one of the black latches contacts broke. I’ve already replaced the latches once on my 16 year old unit. Now, I’m faced with a different challenge, repairing the inner frame right at the location of one of the latches. A new inner frame is around $300. I thought I would try some JB Weld at the brake, and supplement that repair with some sort of “scabbing” between the broken piece and the surrounding frame area. Anyone have any suggestions? Thanks in advance.
  • Correction. The connection points are part of the inside surface of the exterior frame (not the interior frame). The more I look at it, I’m considering running a 1” wide piece of aluminum bar stock (as thin as practical) down either the inside or outside of the exterior frame plastic channel the piece broke from, and riveting it to that channel. If I place the aluminum stock on the outer surface of that channel, I may be able to reuse the broken piece’s connection point. I could also run a piece of aluminum stock down the inside of the track as well, sandwiching the plastic channel wall between the aluminum.
