ralphnjoann wrote:
Thank you for all of your information. I replaced the front bushings at the same time I replaced the rear. I've also added the larger rubber stops, I don't remember the name, that come in contact with the helper springs when loaded. And speaking of springs, could that be the problem?
I'm assuming the rocking problem is unloaded? Or is is when you are loaded?
If its when you are unloaded, the the super-swaystops are the problem. The increase roll-stiffness dramatically (that's why they are so great for campers). If you like the sway-stops, then your best solution is increasing the diameter of the front sway bar. You could also try removing either the sway-stops, or the rear sway bar, to verify the issue.
