pira114
Jun 15, 2016Explorer II
Here's what I found for your model:
Exterior Length 27'11"
Exterior Height 10'6"
Exterior Width 8'0"
Interior Height 6'5"
GVWR (lbs.) 7,000
Dry Weight (lbs.) 5,320
Carrying Capacity (lbs.) 1,680
Axles (lbs.) 2 @ 3,500
Tire Size ST205/75R14C
Fresh Water (Tank Only) (gal.) 37
Black Tank Caacity (gal.) 25
Gray Tank Capacity (gal.) 41
LP Capacity (lbs.) 40
LP Capacity with Upgrade (lbs.) 60
Awning Length 19'
Slideouts 1
Furnace (BTU) 25,000
Water Heater (gal.) 6
Sleeping Capacity +6
Based on all that, you just need to go weigh it to see what the real weight is. I'm thinking with the above numbers, you'll be close to good. Which means you'll need real numbers to make sure.
Exterior Width 8'0"
GVWR (lbs.) 7,000
Awning Length 19'
Slideouts 1
44,026 PostsLatest Activity: Mar 01, 2025
