Terryallan
Jun 16, 2016Explorer II
You really need to know the rear gear ratio to have an idea as to what it will tow. IF it has the 3.08. You are looking at a 5000lb max tow capacity. IF it has the 3.42. you are closer to 8000lb. The engine is only a part of the tools needed for towing.
If you have a 3.42 or lower gear. You should be fine with the TT.
44,026 PostsLatest Activity: Mar 01, 2025
