owenssailor
Jun 16, 2016Explorer
You will have a 6 speed. Use the towhaul button - forget about the 3rd gear advice.
Your rear end as mentioned above 3.08 or 3.42. Forget the reference to 3.73 - not available.
If 3.42 you should be fine if your tongue weight is not too high and you use a good WD system.
If 3.08 you will be well below requirements to tow that trailer.
44,026 PostsLatest Activity: Mar 01, 2025
