Grit_dog
Apr 22, 2019Navigator III
"CoG: Your camper should have a marker on it showing the CoG of the camper. You certainly want to get that marker in front of the rear axle. Weight behind (rear) of the center axle put your truck out of balance and results in lighting the front load. This can make steering a bit iffy."
If you hadn't just posted a pic of your truck/camper in another thread showing the CoG sticker behind the center of rear axle, this advice may be more valid to those who don't understand.
Not that anything is wrong with your setup and not that taking a few lbs or a few hundred lbs off the front axel of a HD truck hurts anything, just that folks may think that statement is an absolute.
