smcken2973 wrote:
Thanks for all the responses. Very frustrating to buy a truck like this, try to do it right and then end up having to worry about a couple hundred pounds.
It happens all the time so you're in good company. People just figure a "full size" truck will handle anything, and the salesman wants to close the deal so they go along with it. You're actually in better shape than most half tons with the 5.7/3.92 combo. You have to watch the weight closely but power-wise you're in good shape for a gas truck. You can't switch it now without losing your shorts so just be reasonable on the trailer and you'll be fine with that truck. With just the two of you and a dog you'll probably be okay with the trailer you're contemplating, albeit a little close on weight.
