Freep's avatar
Freep
Help: DC Power cuts out under load
2014 Lance 992. Symptom is power interruption with moderate to heavy DC loads.
During our last trip we started experiencing brief power interruptions when running loads like heater plus charging laptops and radio running, water pump running. This problem happens at all states of charge for the battery. It never happens when there is AC power available. I suspected the Progressive Dynamics mighty mini and contacted them. I was told it's likely not their power center and was told to look for an inline auto resetting circuit breaker. This I have not been able to locate. I was also told that it could be a bad or loose ground wire.
What I have done:
  • cleaned battery terminals
  • cleaned chassis grounding bar
  • pulled all fuses and run the fridge on DC ... still happens
  • inspected all wires and connections
After this problem presented itself I upgraded the solar on the camper and with my MPPT controller I can see that the battery is still working fine during the power outage. The MPPT controller is wired directly to the battery and doesn't experience a power drop.
I've inspected every wire and connection I can find and still can't find the culprit.
Suggestions are welcome.
  • Sounds like you could have an auto resetting circuit breaker. look around the battery for it.
  • wnjj's avatar
    wnjj
    Explorer II
    How about the battery disconnect switch? Maybe try jumping across it for a while and see if the problem goes away. The current through it may be heating it if the contacts are a little poor.
    This fits with your comment that it always works fine when on shore power.
    It also couldn’t hurt to cycle it off and on firmly a few times.
