Area13
Jun 17, 2014Explorer
Boatycall wrote:Area13 wrote:
I really need to get out the door as cheap as possible
How would you like to get off for next to free?
Since you're on Fox Is, and I'm near Tacoma, if you want to come off the island and come get it, you can have my old stock rear sway bar. I recently upgraded to a Roadmaster. Assuming the axle has the mount points on it, all the brackets and bushings are there, all you should need is the sway bar end links and a couple bolts. I'll know more if you come over and I look at your truck.
If the mount points are on the axle, it's an easy install. Do some google'ing for pictures of axles that came with and without swaybars and you'll know.
If you don't have a rear sway bar at all, it will make a huge difference.
PM me and we'll go over the details
Very kind, PM sent.
44,056 PostsLatest Activity: Nov 19, 2013
