- BumpyroadExplorerstick a dime in the slots and turn 90 degrees. open the door and we will answer the other questions.
bumpy - RV17ExplorerOk, one more question, or series of questions I suppose:
1. How do I open this panel? I tried a little but was worried I may force something in the wrong way and break it.
2. What does this panel serve as?
3. What is behind the panel?
Thanks again, you guys are quick to answer!!!! - BumpyroadExplorer
2012Coleman wrote:
And they are on top and bottom so the bozo assembling it doesn't have to figure out which side should be on top.
actually can be mounted either way but the slide should be oriented so that oncoming water/rain/etc. is not forced between sections.
bumpy - 2012ColemanExplorer IIAnd they are on top and bottom so the bozo assembling it doesn't have to figure out which side should be on top.
- rockhillmanorExplorer IIWeep holes.
And it should be on you list of maintenance items to make sure they are cleaned out regularly. Dirt, road grim and if you park under trees bits and pieces and seeds can get into them also.
Plugged weep holes = water inside your RV. - rbpruExplorer IIMy slide window tracks fills with water when I rains. It drains out the weep holes. They use the same track material top and bottom so they plug the top.
- BumpyroadExplorerwho's got the dead horse being kicked jobby.
bumpy - LwiddisExplorer IIDrainage.
- gboppExplorerJust caulk them shut. What's the worst that can happen? :S
And, check back in a year or tow, let us know if there is a problem..:B - mike-sExplorerThe window frame extrusion is roughly shaped like an H, and those holes are above the bar (-) in the H, they don't go through to the inside of the wall.
They're there so any water which gets past the outside window seal can drain out.
44,028 PostsLatest Activity: Apr 07, 2025
